I went to a Subaru Dealership and they told me that I needed a whole radio unit, because of Delamination. It could take months to get the part. Who put on your unit? A mechanic? My car is only 5 years old. Subaru has to step up to the plate.I went with the aftermarket headunit route after my delaminated. Did it through Best Buy and if you get a head unit that is Maestro compatible, you keep every function the original one provided. Things are exactly the same but I didn’t lose anything I used.
I was going to replace it with Subaru but I found out they just replace your old head unit with the same kind of unit and I didn’t want to handle when it delaminated again. Really irritating Subaru isn’t doing more about this.
Interesting, can you see the car informations too? Which model? Subaru dealership told me it was impossible to use anything else besides the Subaru OEM. ThanksI went with the aftermarket headunit route after my delaminated. Did it through Best Buy and if you get a head unit that is Maestro compatible, you keep every function the original one provided. Things are exactly the same but I didn’t lose anything I used.
