B
BD
Hey, all.
I'm seeing a symptom with my 02 WRX wagon which kind of bugs me, and I
don't really know how to explain it intelligently. So I'll explain it
anecdotally.
Right - so I'm sitting idle at a stop sign, waiting for the light to
turn green. It turns green.
I then...
-put in the clutch
-pop into 1st
-let out the clutch, and take off. All's well.
Now: it's at the point when I actually move the shifter into gear where
my question arises. There is usually some resistance felt, until the
tranny slows down once I've engaged the clutch. Once the tranny spins
down, the shifter slides nicely into place.
But SOMETIMES, I am finding, this 'resistance' simply is not there, or
is not as strong as is usually is. The shifter blasts right into gear
with the same amount of force applied to the shifter as normal, and the
gears smack into each other while the tranny is still spinning down.
NOT what I want.
I have seen this behavior when taking off from a stop, when taking off
from pulling out of a parking spot in reverse, and when gearing down
from second to come to a stop.
I have brought this topic up before in the context of gearing down from
second, and the resulting discussions about double-clutching were
valuable. But this is a little different.
I'm pretty sure I'm consistent about how quickly I put the shifter in
after engaging the clutch, but it's possible that I rush it slightly.
I never had this problem with my previous car (91 Toyota Tercel).
Is this a behaviour issue on my part, meaning I just have to be more
careful and make sure I wait for the tranny to spin down at all times?
Or could something be amiss or 'becoming' amiss with the car? Seems to
me that this 'detente' or 'resistance' in the shifter before going into
gear is a Good Thing, and should Always Work the Same.
Thanks!
BD
anecdotally.
I then...
-put in the clutch
-pop into 1st
NOT what I want.
Thanks!
BD
