Problem with 99 Forester power steering
L
Larry
Starting about a month ago, my "engine area" squeaks like mad for about
a minute after I start my engine. I am under the impression this is
the result of something not right with the power steering.
Also, if I am parallel parked and have to do tight steering while
stationary to get out of the space, I notice the steering wheel jerks
and the lights dim in rhythm with the jerking if they are on.
I checked the PS fluid level and it's OK. In my uneducated analysis
either there is air trapped somewhere or the pump itself is on its last
legs. I'd like to have a clue before subjecting myself to the repair
dept possible run around.
Comments?
Larry
Comments?
Larry
It may not fit with all the symptoms you listed - but a glazed or loose
belt might cause squeaking. When were the access. drive belts last
changed? Cheap enough to try some 'Belt Ease' or other belt dressing to
see if the symptoms change.(I assume the PS fluid level is OK.)
Thx for the advice, a little belt conditioner seems to have largely
solved the issue.
Hpy nu yr!
Now that you have found the cause you should change the belt or belts
as "conditioner" is only a temporary cure. JMO Ed Hayes
Aye aye capt!
I've used belt dressing before and still carry a can with me for when other
folks ask. Am I mistaken, or is it akin to overglorified spray glue?
~Brian
