power window stopped working
jim
I've an 03 OBW. The rear-right power window is 'stuck' in the open
position - I opened it all the way this afternoon and when I tried
closing it 2 hours later nothing happened. There is no motor noise,
only the sound of the switch flicking frantically back and forth on the
drivers door panel. I've tried the passenger door window control and
get the same results - nada.
Any ideas (prior to the weather changing)?
Thanks.
Jim.
have you checked the fuse box lately?
Thanks.
Jim.
As far as I can read, there are no fuses inline to the power window
motors. But I checked them all, anyway, and they are all fine.
Jim
Jim
If the lights 'dim' when pressing the switch, the mechanism (window
regulator) may be jammed or the motor may be shorted. If there is no
load on the battery (maybe check with ammeter in line from the batt.)
when activated, probably a bad fuse(seems there is none?), relay(I think
its under the hood), ground, switch, 12V supply. Either way would likely
require goinig into the door.
cq.mec
