Hi Dan!
Any BTDT's on this? My son's Impreza passenger window stopped working
- no motor sound at all. haven't had a chance to look at it, and since
the driver's side works fine I am assuming it's not a fuse. How hard
is it to replace the motor?
TIA
Dan D
'99 Impreza 2.5 RS (son's)
Central NJ USA
It's a PITA, but do-able w/o special tools or anything. You'll
probably end up replacing the whole regulator assy, as that's what
you're gonna get from the salvage yard. Then you'll need to adjust the
window alignment as well. Email, and I'll see if I can find that
section of the FSM and send it along.
Before you rip into it tho, I'd check the master switch (driver's
side), as that is a common failure item. Probably the easiest way to
check, unless you have a known-good switch, is to pull the door panel
on the passenger side and attempt to power the motor directly. Use a
12V source and some test leads with pointy probe ends to poke thru the
insulation of the wires feeding the regulator. If the motor works from
here. you'll know it's a switch issue, plus you can get the window
into the up position this way if you don't feel like tackling the job
right away.
FWIW, a decent yard will generally let you "borrow" a switch to test
the circuit, on the assumption that you're gonna buy it (or a
regulator) if it fixes the problem. Having the original already out
and the plug exposed will facilitate this procedure. I seem to recall
that you could pop the switch out w/o removing the door panel on the
earlier Impreza's, but don't know about the 99's. Try gently prying up
at front and back with a butter knife or something.
Hope this helps. Ummmm, BTDT?
