Positive camber? Halp?
Just got back into a Subaru 🎉
2004 Impreza Outback Sport.
One thing I've noticed is both front wheels have about 2-3 degrees positive camber. There's no camber bolts on the front (I have a set coming this weekend to help),
And I don't see any sign of bent rods, worn joints or and play in any linkage. Shes firm and proper, and drives great (minus the positive camber feel).
Is there something I'm missing? Could I be overlooking a bend rod or bolt? Halp!
Can provide pictures if needed!
Thanks
j0e
First thing to do is find out what the alignment specs call for and go from there. Any decent alignment shop should be able to look it up for ya. That said I've seen special baljoints out there that allow you to adjust caster to some degree but I'm not familiar with your suspension design.
tim203
