pneumatic suspention is a mother#!@r
MOTOR-hed
my air struts will not inflate,I have changed th' relay tested the
compressor,checked th' fuses,and repaired the leaks in the hoses, any
suggestions are most appriciated,thanx
The tank has a pressure switch and a solenoid. May want to check both.
Dump the compressed air in the tank. If the compressor doesn't kick in it
could mean the pressure switch is bad. If the compressor kicks in but the
struts do not inflate it could mean the tank solenoid is bad. If the
compressor does not kick in than suspect the system's control unit which
is usually hidden under the carpet under the driver's seat.
WolleyUrubus
