Hi Snow!
My mechanic said my 1998 Legacy's tapping sound (which goes away warmed up)
may be piston slap. It has 136,000 miles on the 2.2 liter engine. No
troubles with car except for the light tapping noise. Is this a common issue
for Subaru's? I read on one website that the piston slap issue usually does
not effect engine wear that much. Is there any kind of engine treatment
fluid that helps piston slap? Any information appreciated.
On the 2.2l motor, lifter noise is quite common; a tic-tic-tic that
generally lessens as the car warms up.
You could try any of the various oil additives, but in my experience
they won't help much, if any.
As long as the noise mostly goes away when the engine is warm, I
wouldn't worry about it. Once it gets to the point where it's more of
a "clack-clack-clack" that _doesn't_ really go away, you'll probably
want to look into servicing the hydraulic lifter(s).
This isn't a difficult job on the 2.2; the hydraulic lifter is located
in the cam follower (rocker arm if you will), and this is readily
accessible without removing the head from the engine. A pretty simple
DIY project as it turns out.
I've found that swapping in a good lifter for the collapsed one
generally solves the problem, at least for a while. Get an entire head
(a slightly warped one is probably fine, and cheap), or even just the
cam follower assembly from a salvage yard. If the problem persists,
it's an indication that the oil pump is getting tired. (Or that there
is contamination present in the engine oiling circuit; did someone use
silicone sealant when replacing an oil pan or oil pump recently?)
You can readily find instructions for this procedure on the web, or
email me and I'll send you what I have. Takes about an hour, more or
less, with no special tools; 10 and 12mm wrenches and sockets, a set
of needle-nosed pliers, and a cup or so of fresh oil.
Another possibility is the timing belt system. I'll assume that at
130+K you have had the belt replaced. Did they also replace the
tensioner, idlers, and waterpump? Sometimes a failing idler bearing
will start off by making a clicking or tapping noise which may or may
not lessen as the engine warms. If this is the case, it will get
rapidly worse with time, and should be attended to ASAP to prevent
possible engine damage. If you use a mechanics stethoscope to listen
to the running engine, the lifter noise will obviously be associated
with one side or the other's (or both) cylinder head; the timing belt
idlers will sound more front and center. Piston slap, I couldn't say.
If I'm way off the mark, and it _is_ piston slap, there's not too much
you can do about it anyway. Drive the car until it fails outright
(rare), or gets obnoxiously loud, and then either replace the engine
or upgrade to a newer Soobie.
Hope this helps.
