issjoe said:
And where is the EGR valve?
As Tony mentioned, follow the hoses up from the valve covers to a
T-style junction that leads to the back of the intake manifold. This
will be roughly just right of center of the engine (as you're looking
from front of car.) The PCV valve is a screw in unit w/ a rubber hose
(about 1/2" or 12-13mm) clipped on.
Now look to your left (again, as viewed from front of car toward back)
and on the back of the intake manifold you'll see a piece that's bolted
on to the back of the manifold (two bolts IIRC) that has a metal pipe
attached (the pipe might have some heat shield material over it) and
probably a small (probably around 1/8"-3/16" or 3-5mm) vacuum line
attached. This will be your EGR valve.
This is from memory, so if it isn't clear (or correct?), let us know and
I'll go look at the car directly.
Rick C
