T
theskarnes
I have a 2006 2.5x Forester and most every time I apply the brakes I
hear a click type noise not a squeal noise and its not a wear
indicator. The problem was first diagnosed as a suspension problem
but no problem found and then it was determined that the rotor had
excess play in it (back and forth) caused by a loose axle nut causing
the brakes pads to make noise and that fix made it better but noise
still present. You can also hear the noise while backing the car up
after its been sitting a while. Could a brake pad be loose in the
caliper causing the noise?
