Dave N
Hi folks,
I have a 96 Outback, and the parking brake handle is acting flaky: it
doesn't solidly "click" anymore, and sometimes falls back down when
pulled up and released. If I reach my finger in through the opening at
the base of the handle, I can put manual pressure on the "trigger" that
fits in the gears, and while I do that the handle behaves normally
(clicks and holds just fine).
I have a few theories about what might be happening. My first theory is
that the tension has lessened between the thumb button and that trigger.
I noticed that if I hold down the thumb button and move that trigger
around with my finger, there's about 1/8 inch of play, which would be
enough to keep it from latching properly. So perhaps the spring or
cable or whatever runs through that handle needs adjusting.
Another possibility is that that "trigger" (help me out with the vocab!)
has worn down a bit. That bit of play in the trigger may be normal, but
maybe it just doesn't reach as far any more.
Another option is that maybe the parking brake cable needs adjustment.
The Chilton's manual says lifting the brake lever should take 7 or 8
clicks, and mine takes about 11 right now. It doesn't seem right, but
maybe when the cable needs tightening handle can stop latching?
So, are there other options, or is one of these most likely? If it's a
problem with the trigger itself, is there any hope of repair, or should
I just bite the bullet and replace the handle assembly?
Thanks!
Dave
Thanks!
Dave
