3
3Behrs
1999 Subaru Legacy Outback. Trying to determine if recent accident or
Subaru dealership at fault for engine overheat which is resulting in
having to get engine replaced.
Last Friday, Check Engine light came on. Took to Subaru dealer before
heading out on 600-mile road trip after Christmas to fix and ensure car
safe to drive. Also to check oil leak that had occured after a car
smashed into my right front bumper in November.
Subaru tech said check engine light was PO483, that engine cooling fans
were not connected and reconnected fans. First of all, how would
cooling fans not be connected? Could that be the fault of the collison
company not re-connecting them after doing work post-accident?
Secondly, on trip the car made it one-way, then overheated while
climbing Cajon Pass in CA. We took to Victorville garage and they
determined it was a thermostat problem, replace the thermostat, coolant
and sent us on our way.
We did fine for 150 miles until we started to climb up another big
hill. I gunned the engine to keep up speed and it immediately went to
H. We pulled over and the radiator had spewed coolant, engine was
steaming. We called a tow truck and had it towed home 80 miles.
Subaru dealership -- same one that diagnosed PO483 -- said we had a
hairline crack in engine due to overheating and engine would need to be
replaced.
Can anyone help me figure out:
1) Could the Subaru dealership misdiagnosed the PO483 and be
responsible for the overheat
2) What would cause the engine coolant fans to be disconnected? Does
that happen spontaneously or would it be a human error?
3) How long would the engine need to run w/o the coolant fans connected
to cause an engine problem?
THANK YOU for any input you can give.
replaced.
