Outback 2003 break valve issues
C
Cathy
Has anyone ever heard of break valve issues on this car before? I
bought a 2003 Outback H6 about 6 months ago - it has around 29k miles
on it and the VDC/ABS lights have been coming on intermittently
recently. Took to the dealership and they have told me it will be
around $1300 in parts alone to fix the problem (break valves?). This
is apparently not covered under the 5 year powertrain warranty because
it is part of the break system.
The car has never been wrecked.
Any advice? This is my first Subaru and I don't want to have a bad
taste in my mouth for a car that I love.
I know quite a bit about cars in general, and I have never heard of the
term "brake valve," unless the term "brake proportion valve," was what
was meant. I did a Google search in your behalf for "Subaru brake
valve." That term was not recognized by any of the part retailers.
Regardless, there does not exist any components in any car braking
system that could cost $1300 in a car with only 29K miles on the
odometer. Suggest you go to a good independent auto mechanic shop that
has been in business for a number of years, and ask their opinion.
Avoid the chain operated stores like Midas, Firestone, Goodyear, and
the like. Those stores will really over charge you for things you don't
need done. The dealers (sometimes called stealers) are pretty good at
that too. A dealer quoting $1300 is coming across as a stealer.
Your intermittant warning light could be due to a loose wire or a bad
sensor. Those are cheap to fix.
Doesn't sound too familiar. That doesn't mean it isn't the ABS system.
Anything COULD fail. I THINK there have been some bad alternators that
can cause brake and ABS lights to illuminate, though that symptom as
well as bad ABS I seem to associate with models years well before '03.
If the car drives well, perhaps spending a little at another good
mechanic's for a 'second opinion' would be a good idea.
chrispyjoe1
