Five speed Southern California car. Asking price is $1550 (!!!) but
owner claims to have put in a lot of work and has receipts to show.
Odometer reads 128,000. Three owners -- original, long-term second
owner and current owner. I know nothing about these cars except that
they have a good reputation overall. Please offer opinions! Thanks.
I've had two 1982s. First one went to 313,000 miles and no engine work. Had
to get rid of it on account of the northeast body rot. The second one which
I'm currently driving has about 248,000 on it. The front tranny seal is
leaking.
I wish I had a barn and could buy about a half dozen 81s-84s and store them.
Most reliable car I have ever owned.
Only grumps (1982, 1800 eng, 5spd, 2wd) are:
Rear brakes almost always make noise when damp out. Sounds like they are
down to the metal. If I pull the drums and lightly sand the lining it shuts
it up for a period of time. I've just learned to live with the noise. I've
only used Subaru lining.
I've learned to change the clutch cable every 25,000 whether it needs it or
not. I actually had one break at 9,000. It is not the cable itself which
breaks but the ?aluminum? end inside the car.
To change the front tranny seal (5spd) requires cracking the tranny case.
Be very careful tightening the lug nuts on the rear drums, you can easily
warp them. Best to evenly HAND tighten them.
Has timing gears so no need to worry about timing belts!
The piston on the front clibers needs to be screwed in rather than pressed
in. The hand brake works on the front brakes.
The oil pump seals need periodic changing. You can get a seal kit from
Subaru. Do the front crank seal at the same time.
The A/C is a little wimpy on HOT days.
If you ever have to change the clutch use genuine Subaru parts. I've heard
several stories about people using aftermarket stuff and then regretting it.
Some parts are no longer available from Subaru.
Ed Fortmiller | (e-mail address removed) | Hudson MA
* To avoid getting a lot of SPAM junk mail, I have altered my REPLY-TO
* address. PLEASE remove the leading "RUBBISH" from my REPLY address.
* Any Email sent to the address without removing "RUBBISH" will
* automatically be discarded without me even seeing it.
