S
Sheldon
Well, the light has been off and on for several days now, so my mechanic
wants me to bring it in. My question, however, if more about those code
readers and reseters that you can buy off the Net.
They seem to cost around $60 and will give you the error code (you can look
the codes up on the Net), and will allow you to reset the light. I don't
plan on simply resetting the light and going on my way, and I firmly believe
any problem needs to be checked out. BUT, are these devices worth it just
to have so you, as the car owner, at least have an idea of what you're in
for when you do go to the mechanic? Or, you could even use them for an easy
reset if you forgot to tighten your gas cap.
Thanks.
Sheldon
Thanks.
Sheldon
