Nick Lamendola said:
Hi ,
My '99 Legacy Outback (120k miles) has a bad leak at the oil pan. The auto
parts place sold me a cork gasket, yet the dealer says to use Permatex
"form a gasket". I only want to do this once, does anyone recomend the RTV
over cork, or the other way around. I'm leaning towards the RTV.
Thanks
-Nick
Permatex Red sure won't hurt you. Here is the deal on it. Take *NEW* gasket
and lightly (I MEAN LIGHTLY) spread the Permatex red on both sides of the
gasket.
Wipe down the area on both the block and pan.Clean them with carb cleaner
spray (not the foamy shit).You want to be absolutely sure BOTH surfaces have
no pieces of the old gasket left on them. The permatex will fill in any
scratches you made while cleaning off the old gasket.
After the permatex becomes sticky, use a few bolts thru the pan as guide
pins, make sure the gasket is positioned correctly.Remove the bolts.Lift the
pan into place and insert about 4 bolts as far apart as you can.Do not
tighten ANY of the bolts, until ALL bolts are place.After they are all
started, finger tighten all of them, watching the gasket to make sure it
stays in place.Snug them down in a crisscross pattern.USE A GOD DAMN TORQUE
WRENCH!!! No exceptions!
If this is done correctly, this will never leak again.I have glued dirtbike
engines together with this shit.....absolutely amazing stuff.
RTV.....I don't think so.While it can take high temps..it takes forever to
set up, and it doesn't fill in or get as sticky as Permatex.
