I second this, from experience, BUT if you suspect a blown headgasket, but don't have an external leak, there are other means to verify. I'm not a pro, but believe through research, that it could fail internally to cause leakage into the cooling system? From reading, have seen reports of it allowing exhaust gas into the coolant, heating it substantially (overheating). This can be tested, too.Yes, a blown head gasket can cause an external oil leak. From underneath, you should be able to see the oil leaking from between the engine block and the head. This is from "voice of experience" -- this happened on my Forester.
At what point would/will the engine start to run badly?I second this, from experience, BUT if you suspect a blown headgasket, but don't have an external leak, there are other means to verify. I'm not a pro, but believe through research, that it could fail internally to cause leakage into the cooling system? From reading, have seen reports of it allowing exhaust gas into the coolant, heating it substantially (overheating). This can be tested, too.
