L
Leo Dellmora (TsunamiGreen - AndoverNE)
Well, my 99 OB Wagon has had an oil leak for a while and last month I did a
tune-up (changed plugs, wires and the PCV) The PCV came out looking quite
bad (I'm sure it was plugged).
Well after the installation of new PCV I've had no smell of oil and the
front leaking seems to be gone.
This all makes sense because the crankcase pressure (which should not be a
pressure at all) was probably forcing the oil past the seals. With the new
PCV this pressure is not a pressure at all - it is a vacuum.
Talk about a cheap oil leak fix!
