oil change
T
Tim Conway
Hi Everyone,
I have a 2000 Forester L and instead of using the high-priced dealer I went
to my cousin (who's well spoken of as a mechanic) for my last oil change.
I've noticed some drops of oil under the car. I seem to have heard that
there is a "crush washer" that goes on the oil filter. Is it possible he is
unaware of this? TIA for any help.
Tim
The oil filter has a gasket. I think what you are thinking about is
the crush washer on the drain plug. Only a couple of possibilities
here: your cousin didn't use a new crush washer on the drain plug or
forgot to reuse the one that was on there, filter is loose, drain plug
loose. If the filter is loose/leaking, a visual inspection should
confirm this. If it is the drain plug, just live with until the next
oil change and make sure a new crush washer gets used.
The only place I could find these washers was at the dealer. Think for
about 75 cents each. You take a chance reusing as I discovered when I
first started changing my Foresters oil.
Tim said:
Hi Everyone,
Tim
More likely the home garage mechanic (or you in providing the parts)
neglected to buy a replacement washer. The crush washer has to be replaced
for each oil change. The nylon washer can be reused but it could be damaged
so replace it, anyway. If the mechanic worked on the car in your garage and
that's where the car still resides, perhaps it was part of the mess of
crawling under your car and trying to do the oil change under limited space
(i.e., some oil gets splashed out of the drain tray, drips off the wrench,
or drips off the plug after reinserting it).
Why not just call your cousin to simply ask if he replaced the washer
(regardless of what type it is)?
It maybe that the oil filter just needs to be tightened a little.
It's common, when they get warm, they may not be as tight as they need to
be.
Tim Conway said:
Hi Everyone,
went to my cousin (who's well spoken of as a mechanic) for my last oil
change.
is unaware of this? TIA for any help.
Tim
Thanks everybody for your replies. I'll ask my cousin when I get a chance.
Tim
