Y
y_p_w
OK-
Just got the oil analysis results for my 2004 WRX back from Blackstone
Labs. Just to recap, I performed my first oil change at 3000 miles,
and saved a sample to have analyzed.
The averages for a 2004 WRX seem to be exactly the numbers I have. I'm
guessing that mine is the only one they've received a sample from so
far. They do have "universal" averages, which I have in parentheses.
I assume all numbers refer to parts per million (ppm).
ALUMINUM 4 (4)
CHROMIUM 2 (1)
IRON 30 (8)
COPPER 45 (5)
LEAD 8 (2)
TIN 2 (1)
MOLYBDENUM 894 (78)
BORON 148 (101)
SILICON 80 (7)
SODIUM 6 (7)
CALCIUM 1775 (2559)
MAGNESIUM 10 (153)
PHOSPHORUS 822 (797)
ZINC 989 (931)
So - as Edward Hayes suggested, there appears to be a very high level
of moly, whether it was a paste applied to the parts or an oil additive/
ingredient. I believe calcium is part of the detergent package. The
phosphorous/zinc levels (ZDDP anti-wear additive?) seem to be close to
normal averages. I asked Blackstone what the original oil weight was.
I got these comments:
"High wear and silicon are both common finds in oil samples from new
engines. The wear is high due to break-in of new parts, while silicon
is from sealers and sand-casted parts. Universal averages show typical
wear metals for an oil from this type engine after 4400 miles use. We
suspect your engine will look that good or better in two or three more
oil changes. This was 5W/30 engine oil with no moisture or anti-freeze
present. Check back to establish solid wear trends. Everything will
look better next time around."
ALUMINUM 4 (4)
CHROMIUM 2 (1)
IRON 30 (8)
COPPER 45 (5)
LEAD 8 (2)
TIN 2 (1)
MOLYBDENUM 894 (78)
BORON 148 (101)
SILICON 80 (7)
SODIUM 6 (7)
CALCIUM 1775 (2559)
MAGNESIUM 10 (153)
ZINC 989 (931)
