H
houndman
07' 5M Impreza trans Seems to be shifting better. The main problem was
the 1st to 2nd shift. Getting out of 1st was hard, and the revs would
drop, by then engaging 2nd would have a lurch is the best way to
describe it, though that probably isn't right. The car has 1500mi on
it, and it got cold out, which I would think would make things worse,
at least when first driving, but the shifting Seems better.
This has become an adventure. Looking for gear oils that might solve
the problem, reading that the GL-5 oil has sulfur in it, that could
corrode yellow metals, so could shorten the life of syncronizers, If
they are brass. Oils like symthetics might be TOO slippery to make the
syncros do what they should, and grab and match gear speeds. Subaru
says an oil that some say solves the problems I have/had isn't
recomended, and they claim No problems with trans durability.
I came across "Cold Welding", where if the oil doesn't stay on/
between the gears, they can stick because of microscopic
irregularaties, which sounded like could be the problem getting out of
1st. The sulfur additive in oils, recomended for Rears forms acids
when temps get above 250deg, which will corrode the yellows. Who says
a trans Won't get that hot, and others say that they can Between the
teeth, from the friction, and hot enough to destroy oils if towing. I
found out about the test for corrison of yellow metals, where they use
a copper strip, and a better one using silver. I look up how hot a
tranny can get, and 300deg isn't unheard of, especially when towing.
Auto trans's cool it with the radiator, and How Hot is the coolant,
250deg?? So what is auto trans fluid get up to? Auto trans people say
300deg, and cool it down to 240-270deg. 175deg is said to be the best
temp for auto trans longevity, so don't know how that would be had,
without an oil cooler. I never worried about auto trans fluid, as long
as it looked good, but the info is making me think about both auto and
manual trans oils.
I am planning an around the country trip towing some kind of trailer,
with some kind of vehicle. I think it Behoves me to learn all I can,
and even for every day driving of a new and old car. 20yr old one only
has 80K on it. I'd like to know what temps the trans oils get up to,
and if the manual trans oil becomes acidic. They Say you should check
the ph of coolant, with all the aluminum and plastic in modern cooling
systems, since acids can corrode aluminum, and make plastics brittle,
and cause failures.
Should get some Interesting replies...
VF
manual trans oils.
and cause failures.
VF
