no defrost
S
subarulover4ever
My subbie has been sitting all summer. It's a 87 & still going. No surprise
there though. I prefer that car over my brand new 06 Chevy though in the
snow. Problem is no defrost. There's heat & air flow, but nothing comes
out of the vent by driver's door or the top vents for defrost. It had
defrost before I let it set for the summer. Is there a sweet spot for
little critters to live in there? I noticed some tuffs of fibers when I
pulled the fuse panel. If so, how can I get it out, or should I just take
it to my trusty mechanic?
Repairing yourself, you could Remove lower dash plastic drivers side, peek
at the left side of heaterbox as you run through controls for different
openings, see if defrost valve is moving (if nothing moves its stuck). On my
87 the vents and top defrost are the top valve, they are actuated by
vacuum.Where there is heat and ir flow, the valve may be stuck or line
broke. its a black small hose on mine, may be the same for you.
Hey, thanks for the fast reply & that solved the problem. It was stuck.
Much appreciated. 200,000 miles & still going it doesn't surprise me that
it has it's quirks. Even my husband born & raised in GM city Flint says
the next car after we trade in the Chevy is a subaru hands down.
The newer subarus aren't the same, but we say that about all cars now....
Glad it works again.
