New Noise Subaru Legacy '98 2.2L
j
Hi all,
Recently I have had my car stored in a covered carpark over Dec + Jan
months in Australia. Had a friend who started up the engines over the
1st month only. When I started driving it, it felt like I had to
depress the brakes pedal quite some way before the car starts to slow
down/comes to a halt. The mechanic said it was due to gung/rust/debris
on the brake disc and would get better on its own as I keep driving
it. Today I discovered a new noise while I was driving. (Auto
transmission) While on the roads, it suddenly became apparent as a
loud noise accompanied acceleration. I don't know if it should be
described as a grinding noise but when I filled up the petrol tank the
noise seemed to become softer though did not disappear completely. The
noise seemed to sound from the back and I thought it rattled the right
side abit. More acceleration, more noise.
What's going on? Is this something I should be worried about? Or just
because of the long period of storage this 11 yr old car is working
up?
Thanks for any help!
Cheers,
Check the heat shields on the exhaust system. They are notorious for
breaking spot welds and making a "running fan blade hitting metal pot" sound
at certain frequencies and power levels on the engine. So it might not be
transimission at all.
Note, if you are feeling a deep powerful vibration, it probably is the
transmission. But if it's a sound you hear coming from UNDER the car,
rather than THROUGH the car it's an exhaust issue.
Two months storage will have no affect (or is it effect?) on a car.
Braking problem could be worn pads and/or low on fluid. Grinding
noise in the rear is often a failing wheel bearing.
Carl603
