Mystery brake fluid leak
I have a 2012 with the 2.5 engine. I lost all brake fluid, but there is no fluid leaving the car. I thought it was leaking into the brake booster, but I took the master cylinder loose and poked some longe into the vacuum tube hole of the booster, bother are dryer than a popcorn fart.
I popped the back seat bottom off, dry as can be. I added more brake fluid and pumped until it went dry, the ground is dry too.
Is there a spot on Subarus that leaking fluid can hide? I am mystified and unstoppable!
Bobby63
