MY97 Impreza - Power Loss
S
SnatchCritic
97 Impreza L 2.2 (auto) - 180k
Starts ok (even in the cold weather)
After warm up, I was driving around town with the rpms normally around
2.5k and then would have sporadic power loss and rpms would drop to
under 1k and had to fight to keep it running. Then power would return
a few seconds later. Have to fight to keep running at stop lights.
I have good gas (with dry gas added)
Air filter clean and dry
Any ideas on what may be causing this? TIA.
- Remove 123 to reply directly
On Mon, 27 Dec 2004 11:33:05 -0500, Gilles Gour
Thanks for the input.
My mechanic determined that is was the ignition coil. It seemed
reasonable, but the next day the car sputtered at a light and almost
stalled. So far so good since then, I will give it a few more weeks
for normal operation before I believe it's in normal working condition
though.
I am waiting for a single digit morning to give it a real test to find
out if the issue has been truly resolved. I'll keep you posted.
Or the coolant temp sensor.
SnatchCritic said:
Well after a few weeks of operation, here is and update:
After finally throwing a CEL, the MAF sensor was dead. I was able to
get a USED MAF @ $75US. It ran fine (about 2 weeks) until today.
When the power loss issue, reared it's head again, while driving on
the highway. 2 to 3 hiccups (sudden loss of power).
Don't rush out and buy a new MAF. It may be a loose
connector or something. Inspect the MAF cable plug
carefully, reseat it, and see if it starts working.
You may want to reseat the connector on the computer
as well. Another possiblility is that a frayed wire
or bad computer is blowing out the MAF.
4ax.com>, (e-mail address removed)
says...
I am assuming that since the MAF, threw the CEL and that the
replacement MAF is used. I am thinking of getting an aftermarket MAF,
any thoughts/ideas on if this is the reason for the power loss and
should I replace it not fully knowing if this was the reason?
Get the CEL read (Autozone, etc). Are you using
a K&N/reusable filter? CAI?
Good suggestions, also, reset the cpu to factory defaults with either a
reader or disconnecting the battery for severla minutes.
Also, on some MAFs, you can replace just the little wire/film sensor
instead of the whole unit - maybe someone will know the part number.
Do you use an aftermarket oiled filter? Some folks have ruined their
MAFs with those.
just some thoughts
1 Lucky Texan
The repair shop said the CEL was a MAFs failure. They replaced the
entire unit & reset the ECU. I have used a K&N in the past, but put a
subaru filter in a while back since the K&N isn't the best fit and
'hums'.
I'll reseat the connectors and check the wires ASAP. So far no CEL
has been thrown, but time will tell. I hope it's not the ECU causing
the MAF to fail...... sounds expensive
I was talking to a VW owner and they had issues with power loss
similar to mine and their Cat was clogged and was the culprit. Any
chance of this being the issue and since it's borderline no CEL being
thrown? The vehicle has 181k on it. Is there anyway to check to see
if the Cat. converter is going? Sensor reading a high (almost out of
tolerance) value, maybe?
thanks for all the ideas.
-SC
MAFs with those.
just some thoughts
1 Lucky Texan
On newer vehicles I think there are 2-3 oxy sensors and some shops can
test cat flow by putting special sensors in the bungs for the oxy
sensors. If the bad MAF or other problems ahve ever made your car run
rich for a significant amount of time the cat could very well be bad.
1 Lucky Texan
