David Betts said:
It really is very simple Andy. If you regularly activate your ABS
accidentally then either you are routinely braking too hard for the
road conditions or there is something wrong with the ABS. If you have
had the ABS checked out and there is nothing wrong with it then the
problem is with your driving. From your use of language it is clear
that you are probably not bright enough to accept that.
David Betts
(e-mail address removed)
Well I'm glad to hear that it turns out that you weren't even remotely close
to being incorrect on this issue. I guess I shouldn't have been surprised.
I'm simply comparing the experience I had with my previous 1993 Nissan
Altima, a 10 year old family sedan, to that which I've had in my WRX. In
the Nissan, I liked the ABS so much that I kept it in good shape by regulary
working it out on a small, inevitably icy, hill with a stop sign at the
bottom in my neighbourhood. Not to worry, I made sure the intersection was
free of any traffic, pedestrians, animals large and small, etc. In the WRX,
not only do I and many others find OURS (not yours) to be too sensitive, it
also seems to release braking pressure, and not reapply it at all quickly,
which seems more like a design flaw than something that could be "checked
out."
The Nissan stopped faster than I could, the WRX does not. Pretty simple.
Since no one mentioned anything about regularly activating their ABS, just
about how badly it worked when it did activate, or about how it activated
when it shouldn't, then your points above aren't entirely relevant.
Rest assured that my use of language was related to a few years of browsing
through this ng and reading your postings which repeatedly dismiss
out-of-hand some common and valid complaints with such condescension as:
"Most of the US complaints about over-sensitive abs are down the
heavy-footed driving" (A direct quote. Remind me which one of us isn't
bright enough again?)
Andy Mason
Genius
