B
bill_hale
Previously posted in the group is a method to use check
engine light flashes to read codes. I have some service info on my 95
Impreza that has CEL ON. I've located the two connectors. I want
to do the check and can count light pulses!
My quandry is: What do they connect to? The data gives a
matrix of the two: Connected, not connected. To what? What
am I missing? Is there a tool? My matrix would have just two lines:
1) Connected to each other; 2) Not connected to each other.
That doesn't seem right.
What am I missing? Am I too dumb to perform this test? Am I missing
a tool?
Thanks, Bill Hale Loveland CO
Subaru Trouble Codes
--- CODE RETRIEVAL --
There are self diagnostic connectors on all models which, when
connected together with the key in the ON position (engine off) flash
diagnostic codes through the LED light on the Oxygen Monitor on the
ECU. The connectors are under the steering wheel, to the left of the
Oxygen Monitor on most models. On Carbureted and Single-Point Fuel
Injected 1989 Models, the test connectors are located on the engine
side
of the firewall, on the driver's side. Impreza models have the ECU
and
test connectors located behind the right side of the dash instead of
the
left. On SVX models the connectors are located behind the driver's
kick panel.
There are four test modes. With NEITHER test connector
connected,
and the key in the ON (engine off) position, the light will display
codes
that relate to starting and driving. With ONLY the "Read Memory"
connector connected, historic codes will be displayed. With ONLY the
"Test Mode" connector connected, a dealership technician can perform
dynamic tests. The last mode is for clearing codes (see below).
a tool?
side
and
the
kick panel.
connected,
codes
