Mirror temp probe
John
Hey all, posted this on USMB byut get only views, no replies...I'll try
here.
Can anyone tell me where the outside temperature probe is for the
autodimming mirror on the '00 OB ltd? I have this model but the temp reads
OC, or error Open Circuit. I originally thought it was reading 0 degrees
Celsius since when I looked at the car it was 32 degrees F outside (equals 0
C for you metric types)
here.
I'm thinking that is not an OEM mirror. The one offered by Subaru does
not have the outside temp, it's compass only. Actually I don't know if
it was even offered in '00. So unless you know for a fact that it came
from Subaru your mirror is presumably aftermarket. The mirror was
probably installed without the temp probe or it may have failed. If
you want to find out for sure you can look for the wires coming from
the mirror and follow the one for the probe if it exists.
The autodim mirror sold by Subaru is made by Donnelly so you may have
the aftermarket version that has temp readout. If it turns out the
probe is missing you can probably contact Donnelly and order one.
Thanks Mulder. After further investigation, and a look in the glove box,
the mirror is Gentex who, according to them, supplies the mirrors in the '05
subes and I assume the '06s. My thinking is that this was replaced at the
dealer for whatever reason. So I'll go through their distributor, Mito, for
the info and instructions.
Thanks again,
John
Thanks again,
John
Ok, yes I think they may have changed to Gentex on the later models.
Gentex and Donnelly are the two OEM suppliers of most autodim mirrors
and they supply the aftermarket as well. It's probably just a matter
of getting the probe and installing it.
