Memory drivers seat
Hi my driver’s seat has stopped retracting on entry and the door switches for presetting the seat no longer works also I cannot register user on the screen settings for memory settings on drivers seat BUT the manual electric switches on side of the seat still move the seat ,any ideas help please
The seat is suppose retract? Sorry I can't give you an answer, I would like to make mine retract.
The retraction feature and memory depend on the trim level and options in question. Lower level trims do not have the auto retract feature or memory. You must have the memory outside mirrors and seats option as well. These features may also use the driver attention monitor on top of the dashboard to operate. The seat position with the driver monitoring is actually done via facial recognition as well as the door mounted switches . The seat memory feature can be had with just door switch activation, but requires an option with seat and outside mirror memory. Is anything restricting the camera view if so equipped? Do the outside mirrors move?
Yes the mirrors move ,the drivers seat can be moved on the seat buttons electrically .your right it’s all done by facial recognition this has not been able to register a driver all of a sudden ,so the retraction on entry has stopped I can’t set up the seat memory on the door buttons .this was all working and set up from new the car is coming up to five years old now so I have to get in after my wife uses it and use the buttons on the seat to bring it back down she is smaller than me ,it has been suggested to check the fuses but can’t see that as a problem? Thanks for your reply
Fuses might be an issue. It is possible camera on the top of the dashboard and/or the door buttons have lost power.
LV_Dan
