V
villenes
Need some input.
Our Subaru Outback 97 recently started blowing cold air when the heater was on. And shortly thereafter the temperature gauge started increasing, potentially overheating the engine. Immediately, turned the engine off and stopped.
At first we thought it was missing antifreeze. When we opened the radiator cap, the antifreeze burst out. We waited until it cooled and we filled the radiator. We did a short drive to test and noticed that we were getting extreme heat -- above normal temperatures however, the temperature gauge was reading normal.
According to the Subaru Owner's Manual, we bled the system at 2500 rpm for 5 minutes, waited one hour and repeated. It seemed to be fine that evening for our 500-km drive from Montreal to Toronto.
Whilst we were in Toronto, we took a small drive and started running into the same problem. The cold air started blowing with the heating at full and the temperature gauge started climbing. We brought it to a Subaru dealer while in Toronto and they claimed it was the head gasket (I doubt it was a true inspection since they provided the answer in less than half an hour).
Without having the job done, we took the car back and drove it to Montreal running into the problem intermittently early on in the trip. Somehow we made it back to the Montreal area and noticed that the temperature gauge climbed once again when we went from 100 to 120km.
(Note: During our return from Toronto, we had the heat running at high in order to avoid possible overheating.)
Looking forward to any input that can be provided.
