Keyless entry 2004 Forrester
C
Chromavoid
A friend and I both have 2004 Forrester XTs. We both have problems with the
range of the key fob. Sometimes it will open the locks at 25 feet, sometimes
only when we are next to the door. We changes the key fob batteries without
any change. Ideas???? Solutions??
Ed in Colorado
with the
sometimes
without
I know it sounds goofy, but you will find the range much improved if
you hold the keyfob in front of your chin while using it. Your body
becomes part of the antenna!
john cline ii who knows this looks nuts, but it works
Everyone complains about the reduced range - I've read it is an attempt
to reduce 'code capture'-thieves. John is right, you'll get several more
feet if you have line of sight and hold it under your chin. Also
experiment with holding it vertical (awkward) or horizontal. '20-30'
feet is normal.
1 Lucky Texan
Same for my 2003 but it was much further for my 1998. This is not a problem
but apparently for improved security.
Frank
I don't have a solution, but my theory is that range varies dependent upon
where you are in relation to the car, i.e., where within the 360 degrees,
not necessarily how far away. I haven't figured out the pattern yet.
"code thieves" makes sense. We tried the chin with limited success
thanks
Ed
To increase your range temporarily, you can charge yourself by rubbing the top
of your head with a wool glove. To avoid losing the charge through the ground,
you should hop in the air. With a little practice, you can open the car from
across the lot.
Florian
OK, now let me envision this. From this post, and others, I've learned that
the way to open my Forester from afar is:
1. Take out a wool glove (if not wearing one, which is rare here on SoCal; I
guess I'll be carrying one now).
2. Rub head vigorously with glove (on or off, or does it matter?).
3. Just before and simultaneous with termination of head rubbing, jump into
the air as far as possible.
4. As maximum elevation is achieved, place the key fob under your chin and
press the button. (Note that the upward motion of raising your arm
vigorously to elevate the key fob also assists in the jump.)
I did not realize owning my first Subaru would involve cult-like practices.
This will easily identify Forester drivers in large parking lots.
HW
across the lot.
Florian
You can smile if you want to, but holding the remote against your chin DOES
increase its range. I've tried it, have no idea why, but it works.
I'd like to see that hop, though! I have a great picture of that! <grin>
Distance is determined by what is next to it and where you are. The antenna
is up front somewhere. If you car is burried by larger cars and you are
coming from the back, your distance should be shorter. If you car is alone
in a lot, your range should be longer. My batteries only last 3 months or
so.
so.
Must be lifestyle difference. I've gone for over a year on original
batteries. Be thankful that Subaru uses replaceable batteries. I've
heard that some manufacturers use sealed remotes and expect you to buy
new ones in the $50 range when the batteries go dead. (People who have
cracked them open observe that the batteries are easily obtainable,
standard models. Biggest challenge is sealing the things back up.)
CompUSA is a great source of CR2032 batteries at about $1 each.
the range of the key fob. Sometimes it will open the locks at 25 feet,
sometimes only when we are next to the door. We changes the key fob batteries
without any change. Ideas???? Solutions??
My '02 ForesterS keyfob opener works from the same distance as when we
bought the car, 2 years ago this week. The batteries are original. I'd
say the keyless entry system has been changed since '02. Bug your dealer
for an answer. Three month battery life, as other's have, is ridiculous.
BoB
J Hurl
