Now for a minority report.
I converted my 1999 OB to run on any mix of gasoline and ethanol. When
I announced this here almost two years ago, I got tons of warnings,
but none of them has panned out. My fuel injectors, pump, tank, hses,
-- all are OK.
What I did not expect was the increase in performance on E85. The car
has more pickup then before. I am not an automotive engineer, but I
suspect that the higher octane the permits more spark advance. (I
learned about the "knock sensor" recently.)
Last year the price3 of E85 was 25% lower than regular gasoline. My
miles per dollar increased by about 10%, although my miles per gallon
was 15% lower. My 16-gallon tank now takes me only 3090 miles instead
of 400 miles.
This year, E85 is relatively higher, so I switched back to the usual
E10. If the car lasts another 100,000 miles (as I expect) the price of
gasoline may go back up above $4 per gallon, and I will be sitting
pretty.
The conversion was simple. All I did was to insert a computer chip
into the electrical control line of each cylinder to give it a richer
range of mixtures. Ethanol is a fine fuel, but the energy density is
30% lower than that of gasoline. So your check-engine light will come
on, complaining about lean mixtures, if you don't use the chip. It is
available for about $100 per cylinder. Installation is easy if you
can reach your fuel injectors.
Many hasty authors write that MPG must go down in proportion to the
lower energy density, but it is not so in my Sube. Again, it is
probably because of the very high octane and the adjustments that the
on-board computer can make to the tuning. Internal compustion engines
waste most of the energy as heat, so any improvement in burning
efficiency makes up for some of the loss of MPG.
So bring on the cheap Brazilian ethanol!
Uncle Ben
