Installing cigarette lighter
Dominic Richens
My 2nd hand 95 Legacy doesn't have a cigarette lighter, that I want for cell
phone/air pump/CDwalkman. So I got one at the local Canadia Tire for 4$.
Before I start pulling the console apart (Haynes manual shows how) will I
find the necessary wires in there? Or should I expect to have to splice the
radio/cassette power?
cheers!
cheers!
Don't know if you'll find the wires there or not, but even if they were, I
wouldn't use them. Subaru cigarrette lighters (at least the ones in the 3
subies i've owned) are only powered when the key is on. Nice "battery
saver" idea, but in real life, a PITA. Cell phones and such don't draw
enough power to drain the battery in any reasonable amount of time.
When I decided to add a second lighter to my Impreza, I ran a single wire
directly from battery + to the lighter socket, and then a wire from the
socket to a nearby ground. Make sure you use wire heavy enough to handle
the load, and put a fuse inline on the positive line. Also make sure to
come into the "cabin" of the vehicle through a grommet or similar, and make
sure to route the wire away from anything that can chafe the insulation
away, and cause a short-circuit.
Good instructions....One additional thought: Put the inline fuse
right at the battery terminal instead of at the lighter outlet. That
way your custom wiring will be protected if some chafing occurs
Japanese cars are like that which I hate.
I made separate circuit using unused fuse slot.
This was to plug in solar panel to keep my battery
charged in winter months parking outside.
Tony
