The touch panel does not respond when the temperature is high in the car. Will work for one or two taps on the screen then freeze. Restarting does not fix the issue. Once the temperature drops scree works fine. Any help would be appreciated
Might help if I let you know this is a 2018 legacyThe touch panel does not respond when the temperature is high in the car. Will work for one or two taps on the screen then freeze. Restarting does not fix the issue. Once the temperature drops scree works fine. Any help would be appreciated
Hey, I have the same situation. Funny, I thought I was crazy when I found that cold interior allows operation of the system and heat freezes it.This is a similar issue that the outbacks have from the same time period. My screen (and others based on other threads) developed bubbles after the heat and now after about 9 months after the bubbles showed up, my screen is unusable. We are hoping for a class action lawsuit to get Subaru to recall it but no luck yet.
