Impreza/WRX/Forester/OBS assembly defects mini-poll
John Opezdol
If you had problems with a recently purchased new Impreza/WRX/Forester/OBS
pitch in here.
pitch in here.
2003 Forester X, minor problems:
- Tape on top of the roof rack loose.
Fixed it myself with some trim adhesive.
- Over inflated tires. (Lots of people report this problem.)
- Dash buzz near the steering column, while driving over rough pavement.
Fixed it myself with a lump of plumber's putty.
- Wind noise from front passenger window.
Well documented problem in this newsgroup.
This poll will end up being misleading and of zero significance.
Statistically if all member in the this news group bothered to take the time
it would still be useless waste of effort and time. eddie
I also have a 2004 Forester X.
What was the inflation on the tires? I have mine set to 35psi or even
38psi depending on how I feel. The max psi on the G900's is 44psi.
I didn't have any of the problems above. I did have a peeve and that was
that it will automatically go to outside air when I set the vents to the
defog position. I had to go in there to do a cut and jumper.
