There are several common causes for a speedometer to stop working. Typically, these malfunctions are caused by, a broken gear in the speedometer system, a speed sensor issue or a faulty engine control unit (ECU). A malfunctioning speedometer may also be due to damaged wiring.i changed the normal bulbs in the dashboard to pretty new leds, for my misfortune after i closed the dash i noticed the speedometer dosent move from 0, any suggestions on what to do?
thank you for the the reply nate, you suggest letting a pro handle it? or there something i can do?There are several common causes for a speedometer to stop working. Typically, these malfunctions are caused by, a broken gear in the speedometer system, a speed sensor issue or a faulty engine control unit (ECU). A malfunctioning speedometer may also be due to damaged wiring.
If you have no previous background of mechanical experience, then I would strongly suggest bringing it to a local reputable mechanic.thank you for the the reply nate, you suggest letting a pro handle it? or there something i can do?
i checked the wiring and its not damaged, is there anything else i can do?
