B
Bob Throllop
Hi all,
I'm trying to pull the transmission out of an '01 Legacy in my garage,
in order to replace the clutch. Well, after getting all the
surrounding accessories taken apart and disconnected, I took off the
bolts holding the trans. to the engine and tried to pull it out, and
it won't budge. I've spent most of this afternoon beating and prying
on it with various blunt instruments, to no avail.
It makes me wonder if there's one more bolt in there that I didn't
take out; although I've looked a thousand times it's rather dark under
there and my Haynes manual is very vague as to exactly how many bolts
there are and where located. I have taken out four long bolts and
removed four nuts from studs, for a total of 8 connections (including
where the starter mounts). If someone has a transmission case nearby,
or a better diagram than I have, can you tell me if that's all there
is holding it together?
One other thing--there are what appear to be a couple of iron pins
where the transmission bell housing meets the engine, about 1/2 inch
long. Does anyone know what these are, if they hold it together, why
the manual doesn't mention them and how to get them out?
Oh, almost forgot to mention--it's a manual transmission.
Thanks for any assistance.
Bob
Bob
