Erasmus said:
I know the recommended change for the timing belt is at 60K (2.2l
engine, 1998 legacy), but how long do these belts really last before
breaking?
Very hard to say...
But experience w/ earlier EA-82 belts tells me a Subaru OEM belt will
generally last longer than an aftermarket part. Maybe by a bunch?
W/ the EA-82s, the book recommendation was originally 60k miles. Later,
I saw on the SOA website it had been cut to approx 50k miles. I asked my
dealer parts guy about this, and he told me it was a CYA move as so many
people were breaking belts BEFORE the 60k on these engines.
My anecdotal experience mirrored what he told me: I had a "name brand"
aftermarket belt break at 52k miles, stranding me in 108 deg heat. Not
fun. OTOH, when I've changed out OEM belts, they looked perfect at 60k
mi.
I don't know if newer single belt designs use a generally more robust
belt than earlier two belt designs, or if there's a Calif. specific belt
using better materials, but either possibility COULD be part of the
higher mileage recommendations. To support the "better materials" idea,
the earliest VW water-cooled engines had NO change recommendation in the
book (you WERE supposed to inspect and adjust at some interval--30k
miles IIRC.) Rumor had it they used steel "cords" instead of the fabric
we see today. I had the original belt on a Rabbit I bought new and sold
w/ 189k miles, and it was just fine.
There's no "non-economic" (or "non-conspiratorial", if you wish?) reason
a belt can't be made that can be expected to go EASILY 150k miles IMO.
In the meantime, you might ask your dealer if the "Calif" and "49 state"
cars use the same belt. If they do, I'd be comfortable extending the
change interval IF you put miles on like we do out here (on average, 60k
miles in most areas may well translate into 105k miles in Calif--TIME
wise. Time's always an enemy regardless of miles.) If not, I'd ask about
purchasing a "Calif" belt next time...
Rick C
