I
In2hoppn
Wondering if someone can assist me with troubleshooting trans code 16 on
1997 Subaru Legacy.
Code indicates bad connection between TCM and ECM, or possibly bad ground at
trans connector.
That is according to Mitchell. But, the wiring diagram (also Mitchell)
doesn't jive with the diagnostic proceedures.
Searching online yielded yet other plug and pin numbers, etc...
Plugs for transmission don't look the same as those either.
It has a connector at the gear selector on right side of trans. Another
plug in harness above transmission, which goes down to left side of trans
where it appears to not be a removable connector where it enters
transmission, if that helps any. Looking for wiring diagram and/or
diagnostic procedures that actually match this car!
Thanks if anyone can help. I don't have the print out from Mitchell at the
moment, but can have it here for my next post if I get any potential help
here...
Currently, I'm running with a fuse installed out at the FWD socket. This
prevents the binding associated with it being in limp mode, which is what
happens when it sets code 16. I was also not able to retrieve any history
codes because again, the wiring / sockets don't match the instructions I
have for doing so. Anyone know if it's bad for it to drive on extended
trips in FWD mode? Seems a lot better than the binding and scuffing off
tires otherwise! I don't have an owners manual for it either... maybe it's
mentioned in there? LOL, I couldn't even find anywhere for what size fuse
to use in it... but a 5 amp is working fine! If I can't get the problem
figured out (and fix it cheaply), I plan on running a circuit and switch to
the dash for the FWD fuse function. Then I'll have a front wheel drive with
a 4 wheel lock switch! That's assuming (dangerous word) that it can handle
100% duty cycle keeping those clutches completely disengaged.
1997 Subaru Legacy.
trans connector.
here...
