- Joined
- Feb 25, 2025
- Messages
- 2
- Reaction score
- 1
Hello everyone.
I have a 2009 subaru Impreza 2.0r N/A (the mexican version of the 2.5) that keeps failing the emissions test due to high HC at idle. The limit is 100 ppm, my car got 109 ppm.
Idle measured (limit): HC 109 ppm (100 ppm), CO 0.23% (1.0%), CO+CO2 14.7% (16.5%), O2 00.6% (2.0%), lambda 01.02, RPM 814
2500 RPMs measured (limit): HC 40 ppm (100 ppm), CO 0.12% (1.0%), CO+CO2 15.2% (16.5%) O2 00.1% (2.0%), lambda 1.0, RPM 2549.
I already changed the oil, air filter, spark plugs (ngk iridium), cleaned the MAF sensor, took the fuel injectors to get cleaned and analysed, ran some catalytic convertor cleaner (Liqui Moly), put some premium unleaded fuel (91 octane in Mexico) and drove it hard for about 20 minutes before the test (half to full throttle until 6500 rpms). It failed before due to the same reason, high HC at idle (never over 200 PPM). What would you suggest? What could be causing this emissions failure?
I'd appreciate the help.
