HELP! FWD light is on.
S
Sheldon
For no apparent reason my FWD light came on and I'm stuck in my own driveway
(it snowed about 2 feet here last night). The car is a 97 Outback, and this
has never happened before. Automatic transmission, no other warning lights
are on.
Any ideas?
Thanks.
Sheldon
Don't suppose you have a 4WD button on your shifter anywhere?
You might also check to see if there is a fuse holder under the hood marked
in little white letters "FWD", up near the firewall. When the fuse is
inserted it should inform the transmission you want FWD only and the
corresponding light on the dash should illuminate.
~Brian
are on.
Any ideas?
Thanks.
Sheldon
Try checking the FWD fuse at the rear right corner of the engine
compartment.
I finally found where the fuse goes. In the fuse holder are two wires that
run under the dash, but I can't follow them any more than that. I pulled
one of the wires out and the car is back in AWD again.
I guess the questions are what kind of a modification did the previous owner
make and why did they make it? Also, why, after three years, did the switch
all of a sudden close, placing the car in FWD?
The car is okay now, but I'm still scratching my head. Bought the car used,
and can't understand why the mods.
Sheldon
Sheldon
I fear you just disabled the light and your car is still in FWD. This
light indicates you have forced the car into FWD mode only by inserting
a fuse or you have a AWD malfunction. My advise would be to see a
competent Subaru mechanic.
Sheldon
Definitely take RW's advice in his post and see a mechanic. If you did
not see the FWD fuse in the fuse block - my suspicions are that either
the wet clutchpack or duty solenoid C are bad and the prevuious owner
was trying to pull a fast one, OR the previous owner thought (wrongly)
they would get better mileage running in FWD mode. There are other
possibilities.
Also, confirm that the tires are all the same size/wear/manufacturer.
But see a good Sube mechanic to check these things out.
I think you guys are missunderstanding what I found. Where you would
normally put the fuse to dissable AWD and put the car into FWD I found two
wires installed where that fuse would go -- one wire where each tab of the
fuse would go. The wires run through the firewall and to a switch under the
dash. Therefore, someone rigged this car so that AWD and FWD could be
switched in and out. Closing the switch would be the same as installing a
fuse and closing that circuit. I'm sure of what I found, and all else is
fine -- wheel size, etc.
When I put the wires back into the fuse holder I can switch the car into and
out of AWD. I tried it. It's not just the light. The car is definitely
switching from AWD to FWD (I live on a hill that's a sheet of ice right now,
so it's a good test).
As I said, I must have hit the switch with my foot getting into the car, and
the switch is very difficult to see.
Question is, why would somebody do this?
Sheldon
the dash. Therefore, someone rigged this car so that AWD and FWD could be
and out of AWD. I tried it. It's not just the light. The car is
definitely switching from AWD to FWD (I live on a hill that's a sheet of
ice right now, so it's a good test).
and the switch is very difficult to see.
Sheldon
BTW, I'm due for an oil change soon and I have a good mechanic. I WILL get
this checked out, but I feel secure it is not an emergency situation right
now. I think you guys are right, and the previous owner may have thought
he'd get better mileage in FWD. If my mechanic can't give me a good reason
to leave the switch wired in I'll remove it -- maybe use it for something
else.
The previous owner, imho, wanted to have the control handy, not using a
cheap fuse. There must be a switch somewhere at arms lenght when
sitting on the driver seat. Check if any of the switches on the panel
can turn the FWD on and off.
I've thought of doing this on my 00 OBW. There have been times, especially
when taking corners on a slick road, where AWD is as bad as RWD if you get
on the throttle. My old toyota wagon had this switch btw FWD/4WD and it was
perfect.
The previous owner most definitely should have told you about the switch or
put it back to stock.
cheap fuse. There must be a switch somewhere at arms lenght when sitting
on the driver seat. Check if any of the switches on the panel can turn
the FWD on and off.
I found the switch under the steering wheel.
especially when taking corners on a slick road, where AWD is as bad as RWD
if you get on the throttle. My old toyota wagon had this switch btw
FWD/4WD and it was perfect.
or put it back to stock.
Not sure if the previous owner was the original owner, but I actually know
him and may give him a call. I agree with you regarding the switch. Can
the car be harmed driving it around in FWD? My old Loyale had a switch in
the middle of the gear shift. I left it in FWD all summer, and the car
"scrubbed" around corners in 4WD on dry pavement. The '97 doesn't do that
as I assume it's supposed to be in AWD all the time.
There is extensive discussion of this type mod and its possible
repercussions here;
http://www.ultimatesubaru.org/forum/showthread.php?t=48865&highlight=awd+fwd+switch
repercussions here;
Thanks for the link, but they are talking about actually locking the car
into a solid 4WD mode. Unlike AWD, the wheels cannot compensate going
around turns, but it gives phenomenal traction. I wouldn't mind an option
on mine that would do that.
Meanwhile, I can't find anyone who can tell me what the advantage of putting
the car into FWD is. One mechanic thought it might be mileage, but he said
I'd have to try it and see. I'm concerned about destroying the car if I do
that. Besides, my thoughts are that if it did work Subaru would have put
the switch on there at the factory, like my old Loyale.
Its intended to be used if you MUST put a 'donut spare' or other odd
sized tire on. Even then, you should really get the tires back in
exactly to right configuration soon.
Subaru says cricumference of tires must be with 1/4" of each other.
Driving on dry pavement with an odd sized tire will be detected as slip
and engage AWD leading to 'binding' in the drivetrain. After you switch
back to AWD - and confrim your tires are all the same wear/size/style -
take you car to a dry, level parking lot and do some figure eights or
other tight parking/back maneuvers. If you sense any 'jerkiness' you
have torque bind. Often expensive to repair.
And that link is about A LOT more than locking into 4WD.
Its intended to be used if you MUST put a 'donut spare' or other odd sized
tire on. Even then, you should really get the tires back in exactly to
other tight parking/back maneuvers. If you sense any 'jerkiness' you have
Agreed on everything. It snowed a couple of feet here and I was driving up
a hill when the rear of the car started to fish back and forth a bit. I
flipped that switch and when the car went into FWD the front wheels pulled
the car straight. So, maybe there are some times it comes in handy. I'll
do your experiment, and know exactly what you are talking about. Might be
awhile before I find any dry pavement around here.
J Hurl
