Hello, I have super high nox emission and I have no clue what i'm doing. (2005 subaru legacy 2.5 GT Limited Sedan 4d) (179853 miles)
I stupidly bought a car to get from home, work, and school but it has no emissions done in the state of colorado. Here you can have a limit of 1.5000 nox emission my car is at about 3.7084. I really like this car and I don't want to get rid of it but I also don't want to spend a fortune to get it fixed. Is there any suggestions or help for someone in this situation.
this is the diagnostic info if this helps
I'm guessing no check engine light.
A thorough scan on the OBD2 might shed light.
I'm guessing cats are kaput.
Try a fuel additive and run it for a tankfull, see if the cheap method works.
EGR and rate of timing advance
If there is no EGR valve (or not opening far enough) (small orifice) and the combustion / exhaust gets too hot, NOx forms
The rate of timing advance affects it too
do not exactly know what your prob is, but:
Most emissions probs come from leaking header/exhaust. just a pinhole will kill the emission levels.
check this before starting to change parts.
Similar Threads
Stuart R
