Ralph E Lindberg said:
Then could you explain why my Legacy, with a manual clutch has one?
Wrong again, they are there to allow a safe tow, with a tow truck. But
other then towing, there really is no reason to ever place the fuse in
place.
Hum, have to fall in on Patrick's side on this one: Manuals have
mechanicals center diffs, as far as I know, so putting a fuse in would
have no effect. The fuse holder may be there but it's not used. Try it
and see if you get the "FWD" sign in the dash. As to using the fuse
and towing, the manual for my automatic 2000 Legacy states that a)
towing should always, ALWAYS be done with all 4 wheels off the ground
for automatics and b) the FWD fuse is to be used when the spare tire
is used.
The automatic's clutch pack has both thick fluid and electronically
controlled clutch plates to manage the transfer of power to the back.
Putting the fuse in disables the electronic part, which moves the
clutch plates, but some power is still getting to the rear so towing
with 2 wheels on the ground would still cause the clutch to heat up
and possibly cause problems. When using the spare with the FWD fuse
the difference in rotational speed between front and rear is probably
not enough to cause problems over the short term.
Scoobymods has info on how this happens for the VDC cars (
http://www.scoobymods.com/forums/showthread.php?t=3047 ), in the first
thumbnail.
Nicolas
P.s. The car behaves like crap when the fuse is in, anyway, no point
in overusing it...
