Fumoto oil drain valves
B
BBB
The Fumoto oil drain valve people are offering a 15% discount through
the end of the year. I'm posting their announcement here as a public
service. Please let's not get drawn into another long discussion
regarding whether these will drain the final eighth of an inch of oil
from your oil pan.
I will attest to the fact that they work, and also to the value of
reading the supplemental instructions that state that the valve might be
kind of tight the first time, so you are advised to open and close it a
few times, possibly using pliers, before installing.
Dear Valued Customer
Thanks for your interest in Fumoto Engine Oil Drain Valve. If you have
already purchased one, we are sure you have enjoyed using it for Quick,
Easy and Clean Oil Changes.
YM International Co., Authorized online retailer of Fumoto Engine Oil
Drain Valve, wishes to provide you and your friends with a SPECIAL 15%
DISCOUNT OFFER to thank you for your supporting our business and
celebrate the Holiday Season.
Using SVC5 as a discount code, you and your friends will get 15% OFF
when ordering at online store: www.fumotovalve.com This Special Offer is
for limited time only. Expiration: 12/31/03
Thank you for your business and happy oil changing!
Best regards,
Yoshi Mizukami GM- YM International Co.
P.S. Please take this oppotunity to send this unique product as a gift
to your families and friends. They will be glad you did!!
This offer expires December 31, 2003.
from your oil pan.
I have one. Excellent quality of construction and leak proof.
The only drawback I find they have is as following.
The first time I installed one on my 96 Legacy, the little locking
lever was tucked behind the valve and I tought this was cool and
probably bilt in at the conception stage.
I had then to replace the oil pan and on the new oil pan, when the valve
is properly torqued, the little lever is hanging down and could catch on
something and maybe open the valve if I'm unlucky.
I intend to use a tichker whasher at my next oil change.
So if you buy one, have more than one washer to make an adjustement if
necessary.
Fumoto valves do not drain all the oil unless modified. Look at
www.Scoobymods.com to see how to modify the valve. I personally like the
security of a oil drain plug. eddie
