R
Remco
My daughter's 95 impreza had its drive plate bolts walk out so had to
pull the engine about a month ago.
I replaced the oil separator cover, the timing belts, water pump, some
hoses, etc. I had lifted the engine in two weeks ago, but that's when I
found out that the torque converter's mounting holes (the ones that
mount the drive plate) were buggered out torque.
So after that was remachined, I finally got a day off today to lift it
in.
The thing is that it runs rough. I lent out my timing light, so can't
tell whether the timing is correct. Can one adjust the timing on this
car, since it doesn't have a distributor?
I did not replace the exhaust header's gaskets - should they have been
replaced?
The car sounds loud and has the 'fweem' sound like a VW bug - it also
has very little pick up.
After an engine has been hoisted in, should something special need to
be adjusted or reset? With previously used exhaust gaskets, could there
be an exhaust leak so the problem really is the lack of backpressure?
Any suggestions are appreciated!
Remco
in.
replaced?
Remco
