Hi all. Other than fuses (I checked) what would be the most likely
suspect-part or connection I should look at to see why my CC has stopped
working. Not sure where the sensors are. I was given to understand
there's one in the rear and possibly one on the inside of the car. '96
Legacy Outback.
I'm probably not giving you some vital info, so let me know what you
need to know, and I'll check back with the group soon.
Thanks in advance
I have a Legacy wagon manual shift 2.2L and I'm installing the cruise
system from donor vehicles.
So far, I've discovered the following parts as making up the entire
system:
1. Vacuum unit and cable - attached to the throttle body next to the
accelerator cable and bolted to the firewall in the engine compartment
right in front of the driver. There would be a rubber diaphragm
inside this thing and I've had that crack and fail in other older
vehicles.
2. Vacuum control unit - over on the right side (passenger side)
engine compartment bolted to the side of the strut tower - connected
to #1 by a small metal pipe. There are rubber hoses connecting these
things and they could be cracked, or come off, or the vacuum unit
might have failed.
3. Clutch switch - turns off the system when you depress the clutch
pedal
4. Brake switch - same function as clutch switch.
5. Main CC system switch on dash. This has a light that comes on
when the system is "on".
6. Steering column paddles - set, etc... I haven't had a chance to
examine one of these yet.
7. CC computer - should be on the passenger side just to the right of
where the passenger's feet would be.
So far as I know, those are the main parts. The two pedal switches
could be misaligned, turning the CC system off.
That's about the limit of my experience with the CC system on this
vehicle right now. I hope to know more in a couple of weeks when I'm
finished.
Dave
