R
ryan
I have a 1992 Subaru Loyale 4x4 wagon, about 259000 kms. (first clutch, I
believe)
1st Problem: when slowing up to a stop light, with the clutch pedal down,
the car seems to jerk along until the brake finally stops it.
At first I thought it was a "dragging clutch". I've tried shortenning the
cable the get the pressure plate to pull further away, but
from the flywheel, but this has no effect. The engine leaks a bit of oil,
so I thought that maybe some dirt/oil got on to the pressure
plate and is causing it to drag. Fixing this would probably require taking
it to a mechanic, so I might as well get a new clutch
well I'm at it. But this will be $1000Cdn (according to the mechanic -
they'll fix the seals while they're at it)
But, could this be something else? Could the "hill holder" be reacting in
some wierd way? Maybe I'm just really bad at adjusting
my clutch? (i've followed my manual, but ... who knows?)
2nd Problem: I get an intermittant "check engine" light. I've checked the
code, and its for the EGR Solenoid. (34)
I took the solenoid switch out, and tested it by hooking it up to the
battery. It seems to work fine, opening and closing
with applied current. Then I bought a multimeter and tested the resistance.
I forget what it was, but it was very close to
what it was supposed to be. It must be a vacuum leak, or the EGR Valve
itself. Apparently you can
clean these, so I tried to take it off, but the bolts are really rusted in.
I'm not sure I should go to the trouble of buying
a bolt remover to get this off. I've tried to clean it with WD40 without
taking it out, but this didn't do anything. Any suggestions
on cleaning it?
Any ideas would be greatly appreciated.
Ryan
believe)
on cleaning it?
Ryan
