Adam Helberg said:
Just got back from the dealer from a 30K mile maintenance work on a 2002 Outback
Legacy, which had basically no problems. The cost came out to over $900 with taxes.
It seems very expensive. I'd be interested to hear what others have paid for this
service.
What all did it include? It's not uncommon for dealers to tack on
goodies that aren't in the factory service schedule... $900 does
sound pretty stiff for a 30k service.
$510.55 is what a 30k service (service level C) goes for in suburban
Chicago. Includes: Oil, filter, plugs, air/fuel filters, cooling
system service top off fluids, lube susp and seering clean throttle
body, service brakes, replace brake fluid adjust parking brake,
automatic transaxle service, rotate tires, check tire pressure,
inspect clutch lines, hoses, adjust clutch pedal free play, lube
throttle linkage, inspect power steering hoses, adj drive belts,
inspect cuirse control, front/rear bearings, manual tranny service,
rear diff service.
For $860 you get service level D, called for at 60k miles, which adds
replacement of timing belt and cam belt tensioner.
So for $900, if you got a new timing belt and timing belt tensioner,
you got a decent reasonable price. But, those services were done
unnecessarily early.
Bes tRegards,
