Coolant Sensor Install
G
Gerald Graf
I am looking to install a aftermarket gauge pack on my 2002 Impreza
which consists of a Oil Pressure, Water Temp and Voltmeter. I have
installed the oil pressure gauge and am about to install the water
temperature sensor. The problem that I have is that there's only 1
place to get the coolant temp and it currently is taken up by the
factory water temp sensor. My plan is to take it out and screw in a T
type connector and then screw in each sensor into this T connector. My
worries at the moment is that since the factory sensor will no longer
be submerged in coolant that it will make the computer believe the
engine is cooler than it actually is. Am I correct or do you think its
nothing to worry about?
Also is there any other place that one can install a second water temp
sensor?
Thanks
Gerald
Never mind about the post, I have found that there is a plug which
seems be designed exactly for this which is located just beside the
stock temp sensor, which is open on Subaru's earlier that 2002 with the
2.5, after that year it seems like its used as a passage way to help to
heat up the throttle body. The only place that seems to be left to
install such a sensor is in the rubber hose just before it enters the
heater block.
Hope this helps anyone else with the same issue.
AMARIAL
