Hello petrolheads,
I have some problems with coolant disappearing in my Forester 2.0Td 2012 (EE20Z Euro5 diesel engine). Last year when I bought it I had to replace the coolant reservoir, I've flushed and cleaned all the hoses and radiator and put in blue coolant as recommended.
After a couple 100km coolant became brown (it stayed brown since then no matter what) and started disappearing a little but there wasn't any foam or bubbles in coolant, oil was as new and level was the same as when I replaced it.
In summer I had to top it up every ca. 300km, but then in the winter I went over 5000km without losing any coolant but now when it's summer again I have to top up again every ca. 300km (after that reservoir is usually completely empty).
There isn't any visible leaks under the engine, engine runs fine and it doesn't smoke (except black when you floor it hard)
Last week I did the oil change and oil was at the same level as last year also it didn't have any signs of coolant (oil cap and radiator cap are both without any foam)
Does anyone know what else should I check and replace? It could be blown headgasket?
Thanks
Thanks
